Old 08-21-2007, 02:05 PM
sam666 sam666 is offline
Angry dodge caravan 1992
hi I have a dodge caravan 3.3 L it misfire and pop shop change fuel pump map sensor crank sen ox sen plugs wire coil pack check comp at 150 and 145 also change computer.can you HELP
Old 08-21-2007, 05:49 PM
hotrod_chevyz's Avatar
hotrod_chevyz hotrod_chevyz is offline
Re: dodge caravan 1992
Probably an intake gasket leak...
Old 08-21-2007, 10:42 PM
UncleBob UncleBob is offline
AF -Advisor
is there a code? Whats the code?
When does it misfire?
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
