| F Series Forum covers questions and discussions regarding Ford F-150, Ford F-250, Ford F-350, Ford F-450, Ford F-550, Ford F-650, and Ford F-750. |
Brake lines
I have a '98 F150. I popped a steel brake line that runs to the back of the truck. The line is in 2 pieces coming off of the proportioning valve and meets a brake hose just about at the rear axle. It broke at the point where it joins the brake hose. I'm wondering if anyone has replaced this line (these lines) before. I got the bad section out already (the back 1/2) and got a couple of pieces from NAPA or O'Reilly's to replace it. I can't seem to match up the "off-the-shelf" connectors to the fitting that Ford used. I'm about to pull the front piece out and bend up one using the same off-the-shelf pieces from NAPA. I don't really want to do all that. It looks like an ugly piece to bend and replace. I asked the dealer about it and they said they would need to bend one up.
Any guidance would be appreciated. |
Re: Brake lines
Take your old fittings back to NAPA and match them up. They should have the right ones.
Re: Brake lines
My son has a 94 F150 and we did several brake lines last year. Very few people stock individual brake lines. I beleive there is a company that will sell you a complete prebent stainless set - big $$$.
The most challenging part was realizing that all brake lines from NAPA, Autozone, etc have the same size fitting on both ends. Ford has several lines that have different fittings on each end - I think it is to prevent a wrong hook up at the factory. You have two choices: 1. You can purchase adaptors at the local auto parts store. Make sure you purchase the ones for steel brake lines. 2. You can buy fittings from different sources on the net and make your own. You will need a tubing cutter and a flaring tool. Hope this helps. |
Re: Brake lines
My thought now is to simply replace all the lines from the proportioning valve back. This is a good idea for my truck anyway due to the amount of rust under there. |
Re: Brake lines
Re: Brake lines
Re: Brake lines
Sorry about your auto parts stores not having the right fittings. The NAPA here always does or else has the right adapters to fit. Yes you can cut and flair your own and use the old fittings.
Re: Brake lines
Re: Brake lines
Re: Brake lines
I have to get my truck rolling - and stopping - again.
Re: Brake lines
Thank you folks for all of your help. I guess I should have updated this post earlier, sorry.
Soaking the old fittings worked like a champ! I got the old guys loose, fitted 'em up on the new lines and I'm good to go again. Thank you for all the suggestions!!! |
Re: Brake lines
Would you guys be able to help me with a proportional valve. I had to cut my hoses and install a new one. It took about three weeks to get the part. Now I am unsure I have each pipe connected correctly. I have tried to bleed the brakes. The front bled but would not stop the truck completely. The rear when I opened the valve did not let out air or brake fluid? I would think it has to be in where I connected those lines.
I reversed the two lines coming from the master cylinder to see if that had been reversed. It did not change anything. Thanks for any help! Please email if you would like [email protected] |
