Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 08-21-2007, 02:18 PM
xXxHawkxXx xXxHawkxXx is offline
Squeeky Windows?
I have power windows that are completely stock, but still work very well. The passenger side window has always squeeked when being rolled up. Now, the drivers side is doing it. I used to think nothing of it, but now that tow windows do it, I'm not sure what to do about it. Are the motors similar to brakes in which they squeek when they need to be replaced? Or do I simply need to take off the door panel the WD-40 the heck out of it?
Thanks
Old 08-21-2007, 06:40 PM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
Re: Squeeky Windows?
WD-40 will dissipate too quickly, some motor oil on the nylon band track should fix it. WD-40 is what you should use directly in the window track however as motor oil will probably end up getting the glass.
Old 08-21-2007, 07:14 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Don't even use motor oil - use heavy grease (all purpose grease or axle bearing grease).
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
