Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 08-21-2007, 12:49 PM
rodeo157 rodeo157 is offline
95 blower fuse melt problem
hi, on my 95 rodeo. the blower motor will just stop, when i check the fuse its melted, it will melt the fuse everytime, but nothing else. what would cause the fuse to melt, it dont pop. just melts. thanks
95 Rodeo 3.2L v6 5spd 4wd, 31" tires, toyota rims (for now)
Old 08-21-2007, 01:58 PM
trooperbc's Avatar
trooperbc trooperbc is offline
Re: 95 blower fuse melt problem
i'd look for a 'weak' short, or a weak ground even. first step might be to run the blower at the high speed setting to see if that makes a difference, which bypasses most of the resistor pack that adjusts the voltage to get the slower speeds. set the speed before you turn on the ignition. and/or bypass the diode back and run the blower from battery voltage.
at least you are ruling in or ruling out the resistor and/or the motor, and then you can go from there in your troubleshooting.
//bc
1992 trooper 3.2L v6 sohc automatic...as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
Old 08-21-2007, 03:09 PM
well i only run it on high because my blower doest blow real hard. its hot hear in so cali. should i upgrade all the ground cables. mine are really make shift. i only had it 6 months. but this problem is a recent thing
Old 08-21-2007, 11:20 PM
Cat Fuzz Cat Fuzz is offline
It probably doesn't blow real hard because the blower motor is going bad. Soon it will just stop. Replace it.
