Old 08-21-2007, 12:24 PM
J_SHADOW J_SHADOW is offline
<b> I Need Help !!!!!
ok Going right To The Problem My Car Has No Spark I've Checked The Relay, Fuses Changed Pluggs And Also Put A Working Distributor my Pump Primes And Everything Seems To Work Fine The Motor Turns Over But Theres No Spark Is There Like Another Main Ground Other Then The One On The Thermostad??? Oh And I Also Have 4 Wires In The Back Of My Motor Right On The Hardness I Dont Know Were They Lead To They Are Cut Off 1-is Black And Yellow 1- Red 1-blue And I Think The Last 1 Is Black If Someone Knows What Wrong Let Me Know Please I Need To Turn On This Car
Old 08-21-2007, 01:33 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: <b> I Need Help !!!!!
Year make and model and engine?
Where do the wires go to?
How did they get cut off?
MT
Old 08-21-2007, 06:15 PM
ok Is A 1991 Crx And The Motor Is A 95 D16y6 I Dont Know Were The Wires Go To Because My Boy Gave Me The Hardness Cuz His Car Got Rear Ended And I Had Lost Mine And When I Got It They Were Cut Off Also My Ecu Plugs Were Cut Off Cuz Before They Did't Have The Conversion But I Got The Stock Plugs And Put Everything Back Unless Theres A Wire U Might Know That Would Give Me Spark
Old 08-21-2007, 06:27 PM
MT-2500's Avatar
AF - Advisor
This is the Blazer forum.
Is this a Blazer?
We need the year make and model and engine and transmission size and engine code 2W or 4W to be able to help with the wiring.
MT
MT
