Old 08-21-2007, 09:29 AM
gilbertrios gilbertrios is offline
98 voyager Power locks keeping locking every 30 seconds!
When it is off, the power locks keep locking every 30 seconds! Can someone please HELP!!
Old 07-03-2008, 09:38 AM
rocky_island_99 rocky_island_99 is offline
Re: 98 voyager Power locks keeping locking every 30 seconds!
I'm having this same problem, but haven't seen any solutions. Does anyone have any Ideas.
By-the-way....I have unplugged each door lock switch (until the locks activated again) to insure that the door switches are not shorted, but don't know what else to check.
Thanks
Rock
Old 07-03-2008, 02:41 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Find the fuse box next to the battery (PDC) and pull the IOD fuse for 2-3 minutes then reinstall. This will reset the Body Control Module (BCM). The BCM controlles most electrical functions in the van. The BCM and the door locks are powered when the ignition switch is off. The door locks are just waiting for a signal from the BCM to actuate.
Next time please post a new thread instead of reopening a year old thread.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 07-05-2008, 06:14 PM
EZFrank EZFrank is offline
You can also see if there is a relay for the door lock i know my fans stayed stuck on would not shut off and i finally found out it was the relay was messed up and would not shut off. good luck
[IMG]http://[/IMG]
Old 12-29-2013, 01:40 PM
LesVoyager LesVoyager is offline
Could you please tell me if you were able to solve this Problem?
I Have exactly the same proble. Aufter locking the door with a key fob the door is locked every 30 seconds automatically.
Thank you in advance for any Suggestion.
LesVoyager
