Go Back   Automotive Forums Car Chat > Cadillac > Eldorado
Old 08-21-2007, 08:56 AM
jvorrius jvorrius is offline
Send a message via Yahoo to jvorrius
1968 Eldorado Front left caliper locking
Hi,
I'm working on a 1968 Eldorado. The car has 49k original miles and has been sitting in a garage for 15 to 20 years. Changed all the fluids.....completed tuneup . New brake fluid by pressure bleeding. The front left caliper seems to be dragging. Is there any way to work the pistons in and out to unstick them or is it best to replace both calipers? A bit costly if replacement is required.
Thanks
James
Old 08-21-2007, 01:39 PM
DFBonnett DFBonnett is offline
Re: 1968 Eldorado Front left caliper locking
Before you dig into the caliper, take a look at the rubber brake line. I've seen them collapse internally and act like a one way valve so that the caliper could not retract.
Old 08-21-2007, 07:18 PM
caddydaddy caddydaddy is offline
I had that problem, on the same caliper as his '68 Eldo, with my '79 Deville. A new left front brake hose cured the problem!
2000 Cadillac STS
2005 Cadillac Escalade
2008 Triumph Sprint ST 1050 ABS
