Old 08-21-2007, 07:52 AM
tripper07 tripper07 is offline
99 intrigue will not start... new starter, new battery, i dont know what to do
when i turn the key to start the engine all the lights go out and the starter makes a loud click.. changed the starter and even got the old one tested.. worked fine. thought maybe it could be the battery it wasn't. i cleaned the cables and everything. can anybody help me out?
Old 08-21-2007, 12:05 PM
n0rt0n n0rt0n is offline
Re: 99 intrigue will not start... new starter, new battery, i dont know what to do
Wow I will say that its still the battery or one of the battery cables has oxidized/corroded so bad it won't carry the starting current anymore (and sometimes you Cannot see how bad the cable is when its in the engine bay, remove them)
Old 08-21-2007, 07:58 PM
panzer dragoon panzer dragoon is offline
Toggle the ignition switch (key) on/off a few times repeatedly.
Old 08-21-2007, 09:03 PM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
I would agree with panzer on this one, and if that works, then you might want to try cleaning your existing ignition switch, or replacing it. Clean first though, much cheaper that way.
Turn the key from OFF to ON, you should be able to hear the fuel pump prime if you have the window down and its quiet, or you might need an assitant to listen for it. Also make sure that all of the dash lights come on for a few seconds right after turning to the ON position.
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
Old 08-22-2007, 03:04 PM
burijon's Avatar
burijon burijon is offline
Have you tested the battery with a load on it? Autozone/Advance will do that for you. Sounds like you have a dead battery or at least a bad cell in it. Will it start if you jump the car?
2005 Acura MDX 85k
2004 Acura TSX 96k
Previous 2000 Intrigue head gaskets death
Old 08-23-2007, 03:56 PM
-this is the typical case. Since you are hearing the click the solenoid is operating. =You have enough power to get solenoid to move, but not enough power to get the starter motor to turn the engine.
Look at the connections very closely and cut them back if there is corrosion. Hook up a battery charger to your car 30/50/100 amps and see if it will start.
Be careful working around batteries.
