Go Back   Automotive Forums Car Chat > Lincoln > Continental
Old 08-20-2007, 11:57 PM
p2536142 p2536142 is offline
Airbag Light, Code 32.
I know that this is an open circuit code for the drivers side airbag. I just wanted to know if anyone knew a good place to begin fixing this problem before I dive in. I was not sure if this was a common problem, fied by a common method. Thank you all for your time.
Old 08-21-2007, 07:31 PM
Towncar's Avatar
Towncar Towncar is offline
Re: Airbag Light, Code 32.
The common answer that's going around is "check the clockspring".
Looking at the 1996 manual, there's some connections from the Air Bag that might be bad as well.
>> Here's << and overview. ( > Pg 5 )
Code 32 may have it's own diagnostic procedure as well.
-Steven
1996 Town Car, Cartier
Old 08-21-2007, 08:28 PM
rivguy rivguy is offline
Send a message via Yahoo to rivguy
9 out of 10 are the clockspring
-=-=-DANE-=-=-
Old 08-22-2007, 07:19 AM
dugan50's Avatar
dugan50 dugan50 is offline
Authorized Vendor
I agree with all of the above comments. Code 32 is an open circuit in the driver side airbag circuitry. The only moving part and subject to high failure is the clockspring. This is a flat ribbon wire encased in a plastic cover just below the steering wheel and is easily replaced. Once installed, it should cure the problem and reset the computer by itself. Check out this link for more detail http://www.airbagsolutions.com/docs/Clockspring.pdf
I hope this was helpful to you. My information comes from years of experience in these businesses.
http://www.airbagsolutions.com http://www.stolenandrecovered.com
Airbag Service, Airbag Replacement, Airbag Diagnostics
Thank You,
Douglas Gan
Old 08-22-2007, 01:56 PM
Thanks guys very much. I am going to have to clockspring replaced tomorrow morning. I was going to do the work myself, but i tend to break trim parts.
Anyone have any idea what its going to cost me to have it replaced? The part cost $42.33. Which is not to bad.
