Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-20-2007, 09:42 PM
Andykid456 Andykid456 is offline
Help no oil pressure
Today i was driving and alison i hear a noise so i pull over and pop my hood and see the ac belt was broken and it was draging on the floor so i pull it out. To take my car home and i see i have no oil pressure the motor was not knocking so i added a quart and a half since it was a lil low and i mostly costed home im not sure whats the probablem. i saw a leak coming from my valve cover so im going to replace the whole gasket. i was wondering if my oil pump is shot? and if so is it a pain in the ass to replace its a 95 eclipse gsx
Old 08-21-2007, 01:00 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: Help no oil pressure
How exactly did you know you had no oil pressure again? A quart and a half low is quite a bit, you should check your oil levels more often. How bad is the leak from your valve cover?
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 08-21-2007, 11:50 AM
the leak on the valve cover wasnt that bad but i put 1 and half quarts in and the oil pressure is not moving back up its staying on low i cant even drive the car what does that mean? i know its on low because of the guage in dashboard
Old 08-21-2007, 12:35 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
hmm... im not sure how accurate those gauges are. Is there any way to test it and see if you have no oil pressure? Maybe check the turbo oil drain to see if any oil is going through it. That would tell you if the oil pump was workin.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 08-21-2007, 01:46 PM
Hey if i get and after market guage where does it hook up to? anotherthing is and oil pump hard to change?
Old 08-21-2007, 03:12 PM
Holset powered 420a
Not sure about the 4g63 motor but mine has my oil sending unit screws into the back of the block, when the stock oil pressure sender went. The stock on sucks on the 420a so I just threw it away.
To replace the oil pump you have to drop the oil pan, it shouldn't be to hard.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 08-21-2007, 03:36 PM
inafogg inafogg is offline
there has to be a sender on engine. either on the side of or back of engine block. take it out & hook pressure guage there
Old 09-07-2007, 08:56 AM
flyguy123 flyguy123 is offline
If the oil pump is located on the side of the block like the 420A's then it will take a bit more than just dropping the pan. The timing belt and gear will need to be removed as well as the oil pan. If your doing all that then you should take a look at your bearings also because if your pump is junk there is a good chance your bearings are also.
Old 09-07-2007, 10:55 AM
caniborrow50cnts's Avatar
caniborrow50cnts caniborrow50cnts is offline
Send a message via AIM to caniborrow50cnts
at 3000 rpm, the oil pressure gauge needle is supposed to be somewhere between the 2 middle lines, there are only 4 lines total. it is better to be close to but above the middle line. if your dipstick is at the max and your gauge is above or below that region, you have an oil flow problem
72 Beetle - trashed
88 Escort EXP - dumped
92 Talon - sold
97 Eclipse RS - still own
99 Eclipse GST - still tearing up the asphalt
Old 09-07-2007, 10:56 AM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
The stock guages are not accurate at all. The one on my GSX doesn't work at all yet I know I have rocking oil pressure.
Hook up an aftermarket oil pressure guage and go from there.
You AC belt has nothing to do with oil so while that may be coincidental it shouldn't be related.
1991 GSX 2.3 Stroker
