Go Back   Automotive Forums Car Chat > Pontiac > 6000
Old 08-20-2007, 08:57 PM
gmbwrenchn gmbwrenchn is offline
Cruise has stopped working
90' 6000 LE 130k miles, 3.1ltr. Just recently the cruise has stopped working. It has been acting up by working sometimes, then not. Now it has stopped completly. Where should I start to look for problems first. Thanks.
Old 08-21-2007, 05:28 PM
Re: Cruise has stopped working
Looks like if I am driving along, and push the "slide" button to increase speed, that works, but it will NOT hold a cruising speed by pressing the "side" button.
Old 11-11-2007, 09:24 PM
No one has any ideas on this?
Old 12-05-2007, 03:12 AM
2.8litre 2.8litre is offline
Start by checking for any loose or broken wires. If that still doesn't help, then check the vacuum line that controls vacuum cylinders. Also check any lines that are under the dash.
Old 12-07-2007, 02:00 AM
6000wagonman 6000wagonman is offline
I would stick a vacuum test pump on the vacuum port and see if the diaphram will hold vacuum
Old 01-06-2008, 06:01 PM
Looks like it was the turn signal / cruise handle lever. I replaced it because it was badly busted up from usage. It must have something to do with the way the cruise operates. Thanks for the ideas anyways.
