Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 08-20-2007, 06:58 PM
auto trainy auto trainy is offline
Question Replacing a fuel pump
I have a 95 88 and to remove the fuel pump you must drop the tank,my question is has anyone ever removed one from the trunk?,My 2001 Lesabre has a panel in the trunk that I believe is for that reason,any comments?
Old 08-20-2007, 07:09 PM
maxwedge maxwedge is offline
A990 racer
Re: Replacing a fuel pump
There is none on the car, unless you cut a hole through the floor above the pump body!?
Old 08-21-2007, 01:59 AM
guitarsandcars88 guitarsandcars88 is offline
Dropping the tank is a hassle, but its not too hard.
Old 08-22-2007, 11:48 AM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
Yeup, you're going to have to drop the tank. Should just be a matter of removing the fuel fill spout from the fuel door access and the feed and return lines. Then just remove the single bolt out of each mounting strap.
You might want to siphon any fuel out first as it'll be a bear to move if its heavy with fuel
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Old 08-23-2007, 07:36 PM
Max,has anyone ever seen or heard of making a hole in the trunk for that reason?I remember years ago we use to cut the fender wells out for replacing the blower motors on some GM cars which if anyone ever did one you would know why.
Old 08-23-2007, 09:37 PM
A990 racer
I guess if you could figure the exact location of the pump maybe but the access to the lines would be problematic also. Not recommended.
Old 08-26-2007, 09:25 AM
Thumbs up Re: Replacing a fuel pump
Thank you.
