Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-20-2007, 05:56 PM
Andykid456 Andykid456 is offline
Please help!!!
Hey guys i have another probablem i came accross. The probablem is the Anti-Lock Brake light keeps going on And another probablem what is the fuel aratio screw suppose to be sett at how many turns i have a filter Hks Blow off valve and cat back exaust by apex thats for your help.
Old 08-20-2007, 08:47 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: Please help!!!
You must have no idea what your talking about. There is no screw to change your air/fuel settings. The anti-lock brake light is probably indicating....a problem with the anti-lock brakes maybe? Get that checked out.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 08-20-2007, 09:44 PM
Re: Please help!!!
then whats that phillups screw near the throtle body an eclipse gsx
Old 08-20-2007, 10:17 PM
Re: Please help!!!
Pretty sure your talking about the BISS screw, which adjusts the idle speed.
'92 3000gt SL
Zoom Stage 1 Clutch
Old 08-20-2007, 11:57 PM
Re: Please help!!!
yes whats the turns suppost to be set at on the how many turns if i trist it all the wqay in or how do i know when its sret right
Old 08-21-2007, 12:00 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Please help!!!
The Biss screw is a manual way to help set the idle, the computer should do it for you but if the IAC sensor goes bad you can adjust it with that.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 08-21-2007, 12:53 AM
Re: Please help!!!
Just adjust it until your idle is around 700-800 rpm when warm. I'm sure there is no universal setting for every car, it just depends.
'92 3000gt SL
Zoom Stage 1 Clutch
