Old 08-20-2007, 06:20 AM
GringoPete's Avatar
GringoPete GringoPete is offline
Need advice
The black paint on the door armrests where the window/seat controls are is chipped and looking ugly. I wanted to remove the panel where the switches are and go over it with woodgrain design contact paper to match the woodgrain interior.
Does anyone know how to remove these switch panels and would i have to remove the whole unit, door panel etc??
Just wondering how easy or difficult of a job it would be.
Old 08-20-2007, 08:12 AM
rustbucket rustbucket is offline
Re: Need advice
There is a clip in the center of the front edge that holds the switch panel in the arm rest. Carefully jam a small screwdriver in the center of front edge and pry it up. All the connectors plug into the panel, so you would have to work a bit to get them all unconnected.
Daily Driver: 2008 Chevy Impala - 30000 mi
Others:1993 Chevy S10 - 85000 mi, 2000 Saturn SL2, 1987 Buick Lesabre RIP, 1999 Buick Lesabre
Old 08-20-2007, 11:24 AM
Loekee75's Avatar
Loekee75 Loekee75 is offline
Send a message via Yahoo to Loekee75
Re: Need advice
Also, the clip fastener faces the front of the car, on the side near your power mirror switch. The switches can all be removed from the switch plate with the same screw driver you use to remove it from the door panel (all held with plastic tabs) BTW, let us know how that woodgrain finish comes out, my switch plates are looking pretty bad, too!
http://www.cardomain.com/ride/2653398
1992 Buick Park Avenue (Daily driver)
2001 Saturn SL1 (gas saver)
Old 08-20-2007, 07:39 PM
GringoPete's Avatar
Re: Need advice
Yeah, I figured that the wood grain contact paper would hold up better than the paint as it will just chip off again. Too much work sanding it down before painting etc. Anyway, I think that the added woodgrain would give it a nice touch as an addition to the already woodgrain interior trim. When i do get it done i'll post some pictures for everyone to see how it looks.
This weekend i repainted my center wheel caps as the paint was flaking off and the cream color platic exposed gave the car a real junkyard look if ya know what i mean . So i sanded the wheel center caps down with some 400 grain sandpaper and gave them 3 light coats of auto paint. Looks really good!
Thanks for everyones help
Old 08-20-2007, 09:19 PM
GringoPete's Avatar
Re: Need advice
I think that this would be a good match up with the woodgrain interior trim:
