Go Back   Automotive Forums Car Chat > Opel/Vauxhall > Commodore/VS/VT/VX
Old 08-20-2007, 05:18 AM
spudz1 spudz1 is offline
VR Calais Cruise Control Problems
I am having problems with the cruise control on my VR Calais. Sometimes the cruise will not turn on at all and then I will be driving along and the green ON light will suddenly light up and it works fine for a bit. I can hear the relay clicking on & off behind the dash when I hit the ON button.
I see that there is a module on the RHS of the engine bay that looks like it has something to so with cruise. Can I pull off that plug and reseat it without losing any other settings (does it control other things too)?
Any help appreciated.
Old 09-24-2007, 03:53 PM
Club327 Club327 is offline
Re: VR Calais Cruise Control Problems
Hi. The wires inside the cruise control stalk are very fine and break very easily. Usually, if there's a wire breakage, the stalk will need to be 'flicked to indicate' whilst pressing the faulty cruise control mode. If the cruise control responds to the movement in the indicator stalk, then you have just confirmed that the stalk is defective. You could esily replace it, or if you're cluey enough, you could pull it apart and find the wire breakage (using a multimeter) and fix it. Good luck
