Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 08-20-2007, 04:32 AM
Christophe Salvain Christophe Salvain is offline
Tranny filter : deep pan or not ?
Hi
I own a '00 Burb and it's tile to flush the tranny. BUT I dont know if it commes with deep pan or not.
RPO codes clues may help :
KNP : COOLING SYSTEM TRANS, HD
LM7 : ENGINE, GAS, 8 CYL, 5.3L, MFI, IRON, GM
M30 : TRANSMISSION, AUTO 4 SPD, HMD, 4L60E, ELECTRONIC
On Rockauto there's two filter kit :
CatalogTransmission-Automatic : Filter Kit
ACDELCO Part # TF333 {#25325574}
FILTER,TRANS FLUID 2 WHEEL DRIVE; MAY ALSO USE TF329 IF (4L80E) OR TF337 IF 4L60E DEEP PAN
FILTER,TRANS FLUID 4 WHEEL DRIVE; MAY ALSO USE TF329 IF (4L80E) OR TF337 IF 4L60E DEEP PAN $20.79 $0.00 $20.79 Remove Item
ACDELCO Part # TF337 {#25325578}
FILTER,TRANS FLUID 4 WHEEL DRIVE; MAY ALSO USE TF329 IF (4L80E) OR TF333 IF 4L60E SHALLOW PAN
FILTER,TRANS FLUID 2 WHEEL DRIVE; MAY ALSO USE TF329 IF (4L80E) OR TF333 IF (4L60E SHALLOW PAN) $22.79 $0.00 $22.79 Remove Item
Any advice is welcome.
Christophe Salvaing
Old 08-20-2007, 08:58 AM
hrcslam hrcslam is offline
Re: Tranny filter : deep pan or not ?
You're best bet is to check the VIN at the closest Chevy dealership or Auto Zone and Checker Auto should be able to tell you. Or you can crawl under you rig and check. If your tranny pan looks just as deep as everyone elses then its the shallow one (about 1.5-2") If it looks deeper (about 3-4") then get the deep one. If you have a second car I'd take the filter out of your tranny first then take it to the store with me to verify side by side.
Old 08-21-2007, 12:16 AM
2000CAYukon 2000CAYukon is offline
My 2000 Yukon (4wd) has the deep pan. Pretty sure all 2000+ of the trucks/suvs have the deep pan.
//2000CAYukon
