Old 08-20-2007, 12:42 AM
lancem1 lancem1 is offline
98 Windstar GL DRL
I'm about to shoot this van.. My headlights are on all the time key on or not. I've replaced the switch with another will little results. I know there is a daytime running light modual somewhere... but where?
Anyone help please...
Old 08-20-2007, 08:13 PM
wiswind wiswind is offline
Re: 98 Windstar GL DRL
I looked this up on alldataDIY for my '96, and I'll bet your's is located in the same spot.
It is in the engine compartment, front, driver's side, in front of or under? the battery.
It is hard to tell from the "location" diagram.
Unfortunately, I don't have one, as DRL was not on the Windstars made for the USA market until more recently.
Canada required them long before they were required in the USA.
NOTE, if you "import" your USA vehicle with you to Canada, you will have to have the Daytime Running Light function installed on your vehicle in order to license it in Canada.
I tried looking around in the engine compartment and up under the car for the location that looks like what I see in the small picture that they show under "repair" but did not locate that.
They DO clearly warn that this unit WILL BE VERY HOT, so be careful.
This unit turns the high beam lamp ON at a reduced intensity, without lighting the "brights" lamp on the dashboard, when the ignition key is ON, the headlight switch is set to OFF, and the parking brake is fully released.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 08-22-2007, 12:08 AM
Thanks for the tip... Still unsure what it looks like.. or if this will solve the problem. My brake light on the dash is lit as well.. Wondering if a bad switch at the master cyclinder would cause the lights to stay on.
Any thoughts??
