Old 08-19-2007, 10:28 PM
ChoochCharlie's Avatar
ChoochCharlie ChoochCharlie is offline
Fuel overflow
Had my 97 Grand Voyager for a couple months now.
Noticed that when I tried to top off the fuel tank, it would overfill easily.
Then tonight, the tank overfilled just using the auto-stop at the pump. Splurted fuel all over the ground.
Anyone else? Is there a fix?
Old 08-20-2007, 09:14 AM
Stretch58 Stretch58 is offline
Re: Fuel overflow
Fill at the slowest speed as you approach full. As soon as you hear it starting to bubble in the filler neck stop, as that is as full as you want it anyway in the summer.
Retired USAF/ Nuclear Plant Controls Dude
Had Recently
1996 Caravan 3.0 Great Car
2005 Impala 3.8
Now
2000 GC 125K 3.3
2006 T&C 3.8
Old 08-20-2007, 05:33 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: Fuel overflow
Been on this and other forums for 3+ years and don't recall a thread about your problem. If it's doing it just about every fillup at multiple pumps you have a problem. For now, looks like your only alternative is as Stretch58 suggests. Beyond that I would inspect the filler tube and tank for kinks or dents. Maybe the van was in an accident you don't know about. If all else fails take it to a trusted mechanic.
This may be "out there" but, could your EVAP system be overpressurising or something else is trapping pressure in the tank? That's just a wag you could ask a mechanic about.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 08-22-2007, 11:02 AM
labmik labmik is offline
Re: Fuel overflow
Good day
Had the same problem with my DG 96.
I found the vapor return line close to the main filing line is badly corroded .
Either you change the filing line which is expensive or replace the corroded area with a rubber hose suitable for fuel.
Old 09-20-2007, 03:41 AM
Re: Fuel overflow
Thanks. I'll check.
Old 09-20-2007, 08:03 PM
vipergg vipergg is offline
Re: Fuel overflow
on our 2004 when you fill up and it shuts off thats it don't even think about getting any more in it will overflow . First vehicle i have had that does this usually you can get another $1 into the tank before it shuts off for good .
