Old 08-19-2007, 03:55 PM
backyard68 backyard68 is offline
leak at check valve
Hi
I just replaced the fuel pump in my 1995 gmc jimmy 4.3.
it started up fine, but I noticed a gas leak. after inspection i found
it leaking out the check valve for checking presure. can the valve
be replaced, or do i need to replace the whole nut kit.
Old 08-19-2007, 04:00 PM
old_master's Avatar
Advisor/Moderator
Re: leak at check valve
The schrader valve can be serviced separately. Looks like a tire valve core but has a fuel rated seal. You might have to get it at your local GM dealer.
Old 08-19-2007, 05:37 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
You might try to snug it up a little or push down on it a few tmes on it.
But wears saftey glasses the like to squirt gas in the eye ball.
MT
MT
Old 08-19-2007, 08:10 PM
thanks, i already tried to move the valve up and down with a screw driver
i'll call my gm dealer in the morning to get a new valve
