Old 08-19-2007, 02:56 PM
95DodgeAvenger95's Avatar
95DodgeAvenger95 95DodgeAvenger95 is offline
Send a message via AIM to 95DodgeAvenger95
AWD causing a pull?
My car was pulling to the left so i went and had the tires aligned and its still pulling left a bit, the guy said it has to do with the awd in the back, does anyone know what it could be and how much to fix it? Thanks in advanced.
Black 96 3000Gt Vr4 58k mi, H.H.H. Data logger, RPS MAX, Big16G/14b Combo, FMIC, AEM EUGO, Greddy EBC, SAFC II, 560's, hotwired 255lph, not cats, Solid motor mounts, Faze boost gauge, Apexi turbo timer, full exhaust with 3" ICH Single shot Catback, K&N Air Filter, Front upper strut brace, T-Case Bracket, AC delete, Meth injection, NGK stg 1 colder, 8k HID'S.
AIMING FOR 500+AWHP at ips dyno.
Old 08-19-2007, 03:41 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: AWD causing a pull?
The guy is an idiot. AWD wil not cause a pull. Something is misaligned or bent somewhere.
Old 08-19-2007, 05:43 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
when you had the tires aligned, did the tech make sure to disconnect the rear tie rods? i bet he didn't even know about it.
what year 3S do you have? i'm referring to the AWS system in the back that must be disconnected before the rear tires are aligned, then reconnected afterwards.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 08-19-2007, 06:54 PM
Its a 1996 3000gt vr4.
also the car was pulling to begin with, then i had tires aligned and the pull wasnt as bad hard but still pulled.
Old 08-20-2007, 11:24 AM
Linebckr49's Avatar
if the car still pulled after they aligned it, then they didn't align it correctly. take it back to them and make them do it right, at THEIR expense, since you already paid your money.
93 3000GT base
