Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 08-19-2007, 02:40 PM
Mitsu970 Mitsu970 is offline
okay, another problem
So I just put in a new gauge overlay for my car, and when I was doing it the needles on the tachometer and speedometer fell off. I put them back on and then they were all sorts of messed up. So I figured, hey, I'll start the car, then set the needles at 0 MPH, and about 600 RPM (thats about where it idles), so I did that and to my surprise, the tachometer was FIXED! YAY! but uh, the speedometer not so much. I searched around and other people had similar problems but it isn't an issue with the sensor becuase the odometer still clicks along the miles. I was wondering if anyone knew how to fix it if I just broke a component withing the gauge cluster itself, or if that is even possible. Ok, thanks.
Old 08-20-2007, 01:27 AM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
Re: okay, another problem
normally what people will do is have a friend drive the speed limit next to them, and you just set your speedo to the current speed limit, and that should fix the problem.
2000 Fed. Spec GT-"Lafawnduh"
Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp
Old 08-20-2007, 10:00 PM
I already tried that, like...the needle was working in the morning, then we did that to get it on the right speed. And it just sat there. I is ust hanging out at 25 mph. I took it off and put it back on a few more times but it doesn't move at all anymore. all the other guages still do though
Old 08-20-2007, 11:44 PM
rodbls's Avatar
OK, i guess we always try to start with the simplest solution...so i guess I will sound retarded by asking that you make sure that the needle isnt on there too tight, and that there is no sticky anything on the pivot part of the needle...there probably isnt, but hell, it would be a simple fix. Also, make sure you didnt accidentally unplug one of the plugs on the back of the cluster (not sure if it's possible, but I cant remember if there are any outlets back there that might have gotten unplugged without you knowing it. other than that it sounds like your cluster might be fucked (a cluster fuck if you will...lol)
Old 08-24-2007, 03:16 AM
Thumbs up Re: okay, another problem
well....I feel like a fucking idiot now............ that was the problem. And I had no idea that could happen. My bad
