Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 08-19-2007, 09:16 AM
kevin23 kevin23 is offline
Valves rattle
93 GM 100,000 miles
I have always used the 87 octane rating gasoline and never had the valves rattle until recently. Is it most likely the timing chain being worn?
Thanks
Old 08-19-2007, 01:29 PM
reekor reekor is offline
Re: Valves rattle
When is the last time that you cleaned your egr passages?
Originally Posted by kevin23
93 GM 100,000 miles
Thanks
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 08-19-2007, 09:11 PM
Re: Valves rattle
EGR passages ?? Sorry I don't know what they are, so I guess that would be never...........
Old 08-20-2007, 03:03 AM
Re: Valves rattle
Linky below, and i bet you that they are plugged.
http://www.lincolnsonline.com/tech/00015.html
Old 08-20-2007, 11:10 AM
Re: Valves rattle
Thanks reek........
Old 09-13-2007, 09:51 AM
garrytoao garrytoao is offline
Re: Valves rattle
93 GM 100,000 miles
Thanks
try using 10w30 oil or change the oil more. my 2000 did the same i now use mobile one 10w30 and can now change it every 5000 gmg has 47000 miles
Old 09-13-2007, 02:58 PM
Re: Valves rattle
Thanks for the post Gary, but oil is changed every 3000 miles with 10-30 Motorcraft.
