Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 08-19-2007, 01:42 AM
77CapriceClassic 77CapriceClassic is offline
Starting problems on a 77
About a week ago I went out and started the car. The car started up right away but had a rough idle like it usually does after not being driven for a few days so I gave it a little gas to get it going better. Well instead of getting better, it shut off. Then when I turned the key again, the engine didnt even turn over. All my dash lights and radio come on, then I turn and it clicks but nothing happens. Could this be a bad fuel pump? If so is it terribly difficult to get to? Or does anyone have any ideas/suggestions for me? Thanks in advance
1977 Caprice Classic - 350/350 Turbo Trans
Old 08-19-2007, 01:46 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Starting problems on a 77
Not the fuel pump, but it could be the bulkhead connector for the wiring harness (this is where the harness passes through the firewall). Try removing the center bolt (7mm socket) and pulling it off and then putting it back on, then tightening the bolt. Whatever it is, it's definitely electrical in origin.
A bad fuel pump might make it stall (read: WILL make it stall) but it won't prevent the engine from turning over.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 08-19-2007, 10:32 PM
Turns out it was the starter. We put in a new one then reconnected the battery and nothing happened. We checked it out again and there was a wire that had came apart so we reconnected it tried to start it and it fired right up! Its such an amazing difference. I think the one thats in there was the original because this one fired it right up no problems
