Old 08-18-2007, 09:24 PM
mintrigue1 mintrigue1 is offline
Starting/Electrical problem?
I drove my 2000 Intrigue today and it ran fine. I was home for 5 minutes and went to start the car and it would not start at all. The engine did not turn and then all of the gauges started to move on their own. Speedometer, rpm gauge, temp, fuel etc. The lights would work, flashers would not. This vehicle has a 6mo. old battery. I did jump the car and it started fine. When I was driving it up the road all of the dash lights came on and then shut off. It happened a second time and the car almost felt like it shut off for a split second. Now the car won't start again. Has anyone ever seen or heard of such a strange thing?
Old 08-18-2007, 10:11 PM
burijon's Avatar
burijon burijon is offline
Re: Starting/Electrical problem?
It's the dreaded passlock issue! Many posts about it in this forum alone. You can disable the passlock system entirely.
http://www.automotiveforums.com/vbul...sable+passlock
This may not be the easiest post to follow, but as I mentioned it's one of many. This is my guess.
2005 Acura MDX 85k
2004 Acura TSX 96k
Previous 2000 Intrigue head gaskets death
Old 08-19-2007, 01:01 AM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
Sounds more like an ignition switch issue than a Passlock issue.
The times that the car will not crank, do you have a Security light?
Have you tried cycling back to OFF and then trying to start it again? Then repeating this about a million times?
You can try the passlock stuff, but if that doesnt work, I vote it to be an ignition switch. My car would do that same shut off for a split second thing. I recently took my ignition switch out and cleaned everything really well and havent had any starting or driveability problems since. I was having starting issues as well.
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
Old 08-19-2007, 11:00 AM
panzer dragoon panzer dragoon is offline
check for a loose main fuse-box also (by the battery under the hood). Sometime the main connection gets loose.
Old 08-19-2007, 12:49 PM
LittleHoov's Avatar
Haha, thanks for havin my back on the battery cables panzer, thats usually the first thing I suggest, but I completely forgot this time!
But yes, check the battery cables for corrosion, remove the boots as well and clean it all, not just what you can see. The boots remove by pushing the screw portion out, and then they slide right off.
The most pain free way I have found to clean corrosion off cables is to find a small container of some sort (I used a topless soda can) and fill it up with a mix of water and baking soda(check your fridge). Then soak the ends of the cables in that solution and watch as the corrosion melts right off. Scrape or wire brush what little will be left.
Still really sounds like it could be an ignition switch issue to me, if you want a write up on how to remove the switch, search for a thread titled "Ignition Switch Removal?" by me. Its kinda of a pain, but if it solves your problems its worth it.
