Old 08-18-2007, 07:06 PM
glc4122 glc4122 is offline
97 gp hub and bearing repair problems
hello all i need help. i changed a front hub and bearing,because old one was worn out. after intalling it took a ride and the abs light, trac , check tire pressure light all came on. what is the problem?
Old 08-19-2007, 08:49 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 97 gp hub and bearing repair problems
What brand hub did you use? Were the lights there before replacement? Double check the electrical connection hub side and at the wiring harness.
Timeslip 08/12/06
AF Community Guidelines
Old 08-19-2007, 10:49 AM
hello thank you for reply . the hub is a dnynapack(fenco) and the lights were not on when i changed. the reason for the change it was making a humming noise when driving. i had one changed before a few years ago and the abs light came on so i took it too the garage. the trac light has never stayed on like this before. i checked the connection yesterday and seems to be alright.
Old 08-20-2007, 11:42 AM
jem270's Avatar
jem270 jem270 is offline
You may want to do a little searching on this site. Here is a link where I have been working on mine. I haven't had time to figure out the problem yet. Dealer told me that they would charge $30.00 for a chassis system scan for codes. That would be the fastest and easiest way but I don't have the time to leave a vehicle and pick it back up.
http://www.automotiveforums.com/vbul...d.php?t=733318
1997 Grand Prix SE, 3.8 (L36), 4T60-E (auto) M13
2002 Grand AM SE1, 3.4 (LA1), 4T45-E (auto) MN5
2003 Silverado LS, 5.3 (LM7), 4L60-E (auto) M30
1988 Ford Bronco EB 5.0 (AOD) manual BW1356 & hubs
Old 08-20-2007, 12:32 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
The fact that the lights weren't on before the hub change and are now would tell me it relates to the hub swap. I've never heard of Dynapack/Fedco, is this some off-brand cheapo or something? We've stated before that it is a VERY bad idea to buy the cheap/white box/Chinese hub available for any ABS sensor equipped hub bearing, as you get what you pay for.
If you did the work yourself (or had it done at a garage), did you/they use impact tools during installation? This is another no-no on ABS sensor equipped hubs, the hammering action of the impact wrench damages the bearing/sensor and creates all sorts of headaches.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 08-20-2007, 10:19 PM
BNaylor's Avatar
I agree with Rich. I suggested to him via PM to ohm out the wheel sensor by going across the contacts hub side connector with a multimeter. He should get a ballpark figure of around 1K ohms resistance.
This is addressed to poster jem270 checkout the thread below concerning confirmed located of the EBTCM module.
Click here
Timeslip 08/12/06
Old 08-21-2007, 08:23 AM
jem270's Avatar
Click here
Thanks. I'll try to look at it this afternoon. It's going out of town again this evening and won't be back for a few weeks.
Old 08-26-2007, 06:21 PM
rickisrad rickisrad is offline
I replaced my frony 2 hubs with the cheap ones from CPW and never any problems. It fixed the mudder sound and everything is good.
-As for your lights check the hub electrical connector and make sure the rubber seal is in there did not fall out. if it is missing the connector it will not have a good contact and all those lights will come on. It happened to me luckily I keep alot of old small parts like those so I had no problem after replacing it.
Old 08-26-2007, 07:45 PM
thanks again for the info.
