| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
getting bigger turbo?
I currently have a big 16g. what is the power difference between Forced Performance Big T28 Turbo and a Mitsubishi 20G-5H Turbo? I was on a website but i could not find enough info to compare them and i don't know too much about turbos. Also if i were to get a bigger turbo what else would i need to get? i know that you're gonna need bigger injectors but thats all i know.
Re: getting bigger turbo?
you're gonna need tuning too to get the most out of the bigger turbo
2005 Cobalt SS - not stock
The T28 is a little less than the big 16g you have right now IIRC. There is a quite a bit you need before you get a bigger turbo... I bet if you got a respectable mod list you might realize what that 16g can do. Heres a list of things you should (in my opinion) have done before you even consider upgrading turbos:
-FMIC -Tuning device (DSMlink is what you should really get, but SAFC is an inferior alternative) -Bigger fuel pump (for the 20g you'll need a Walbro 255) -Better fuel pressure regulator (255 out flows the stock reg at idle/low RPM) -Bigger injectors (might as well go big so you dont have to upgrade later) -3" exhaust -Aftermarket clutch -A boost guage -Boost control (I would get a MBC) -Cams -Better BOV (1g if you plan on <20psi, aftermarket if you plan on >20psi) -K&N air filter Get that stuff done first and see what you think. I am willing to bet once you get a good tune at higher boost on that 16g you will change your mind about upgrading... at least for now .
Thank you. Currently I have... - Big16 g turbo -Apexi N1 exhaust w/ 3" down pipe - ACT 2600 clutch -Blitz after market boost gauge // air fuel ratio - I just took out my manual boost controller..thinking about putting an electronic one in -GReddy type-RS BOV -K&N filter Is a front mount necessary to upgrade the turbo? i was planning on getting one Laterrrrr on. The next thing that i was going to buy with the bigger turbo is a better exhaust manifold// bigger injectors + pump // and DSM link for tuning. is there anything else I am missing? mainly for safety precautions so i don't mess up the car lol.. thanks |
I would for sure get DSMlink, bigger injectors, FPR, and a fuel pump before the 20g and I would strongly suggest a FMIC. If you are a 2g, its my feeling that you need a better flowing intake mani too. Theres a couple things you could do, one being a good port job and a SMIM or at least a 1g intake mani. Those stock 2g mani's are fuckin worthless and can choke your car off particularly when you are flowing more air/in higher RPMs. Also, I have a couple exhaust mani's if you are looking to upgrade, I have a stock 2g mani and a pretty decently ported 2g mani as well, PM me if you're interested. |
