Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 08-18-2007, 05:00 PM
submachine69 submachine69 is offline
300zx no boost.
i have a 91 twin turbow 300zx and latly if i get on the freeway i get it hot and then all of a sudden i have no boost at all, i was whondering what all factors play in to the car haveing boost, i know u must have good cylinders that can push out hot exhaust gas to spin the turbo and u also need a free flowing exhaust too, but i was whondering how the waste gate controlled and is it only vacuum lines or is there a valve that can allow vacuum or prevent it that may make the waste gate stick open. i cant hear the turbos spool up so i know its not on the intake side. please if anyone has run into a simalar situation.
Old 09-01-2007, 01:27 AM
Hodo Hodo is offline
Re: 300zx no boost.
I havent had this happen to me but I dont have turbos.... I would be rather surprised if I had a sudden boost surge on my NA.
All kidding aside. I belive the stock turbos on a TT are vacuum controled wastgates integral on the turbos. But these are also controlled by the ECU. which if there is a problem your ECU will go to safe mode and cut boost. You may want to pull codes and see what you get.
And let us know what you find out.
Now I am sounding like the techhelp line for Volvo....... God I need a new job.
Finaly got pics of my car....... after I washed it of course.
Old 09-27-2007, 01:31 PM
robzone0911 robzone0911 is offline
Re: 300zx no boost.
If you are bone stock your ecu controlls boost... if you have an aftermarket boost controller it will have a solenoid that controls the boost. You may just have a major vacuum leak. since any vacuum line connected to the plenum turns to positive pressure when you boost you wouldn't really hear a major leak until it's under boost. Listen for any hissing under the hood at idle. You can also try a boost leak tester.
1...2...3...go! 16.3@85mph 2001 Cavalier Z24 Happily traded for my Z32
Old 10-06-2007, 03:02 AM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
Re: 300zx no boost.
major boost leak...
ZedEx Crew Member #4
Old 10-21-2007, 08:46 PM
stprasinz stprasinz is offline
Re: 300zx no boost.
Does it have the power of boost? only doesnt show up on gauge?
Wastegate stuck open?
good luck.
Old 12-04-2007, 08:36 PM
Eclipsewhipping Eclipsewhipping is offline
Re: 300zx no boost.
poop
Old 12-10-2007, 03:38 PM
Tach_it Tach_it is offline
Send a message via AIM to Tach_it
Re: 300zx no boost.
I agree get a boost leak tester, it connects right in front of the MAF. It is possible to have a vaccum leak also so look for both and get a spell checker.
Carpe Diem!
Old 12-10-2007, 08:46 PM
Re: 300zx no boost.
I still want to know if thats just on the gauge or does it not feel like boost....Aftermarket (mechanicle) gauge....
Old 12-10-2007, 08:50 PM
apostrophe28 apostrophe28 is offline
Send a message via AIM to apostrophe28
Re: 300zx no boost.
you say its only when the car is good and hot?...when was the last time u changed ur spark plugs..and when u did, did u gap them correctly?
Old 12-15-2007, 09:53 PM
Re: 300zx no boost.
Still wondering
