Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-18-2007, 11:27 AM
Gsst98's Avatar
Gsst98 Gsst98 is offline
Send a message via AIM to Gsst98
Boost question
I have a 98 gst witha t-25 turbo its running at 13 pounds of boost is that the normal psi I should be running? I read somewhere that its supposed to be at 15psi.
Old 08-18-2007, 11:37 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Boost question
I believe stock is 12-13psi. You could run a mbc and bump it up to 15psi. I dont know if the t-25 will push anything over that.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 08-18-2007, 02:32 PM
steviek's Avatar
steviek steviek is offline
Re: Boost question
yea 15-16psi is max on a stock fuel setup, However, the t-25 can make around 20-21 if you really have a nice setup but if you do then there's no point in have a t-25
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
