Go Back   Automotive Forums Car Chat > Chrysler > Lebaron
Old 08-18-2007, 09:40 AM
Newbydude Newbydude is offline
94 Lebaron - replaced timing belt/H2O pump
.....but I want to hear the car start and get the water circulating (check for gasket leaks etc) BEFORE putting the timing cover, a/c, alternator, and motor mount back on.
I tried starting it yesterday with only the sparkplugs in (connected), but it just turns over.
Needless to say, the waterpump is timing-belt driven
Any ideas on how to get it cranked?
(V6, 3.0)
Old 08-18-2007, 11:51 AM
taillight taillight is offline
Re: 94 Lebaron - replaced timing belt/H2O pump
It should start. Are you sure you lined up all the timing marks?
Old 08-18-2007, 12:13 PM
Yes, the marks are dead-on. Even cranking it, they (dohc) land perfectly on the mark.
was a pain learning how to line them up, but according to the mfg marks on the engine, it's lined up perfectly.
One thing's for sure.. i'm not reassembling this car until I hear it run. What a PAIN this has been! ha!
Old 08-19-2007, 09:09 AM
Pull #1 spark plug. turn the engine over untill the #1 piston is at top dead center. All the timing marks should be lined up. Pull the distributer cap and check the rotor. It should point to #1 plug wire. It might be 180 off.
Old 08-23-2007, 11:44 AM
MKA17 MKA17 is offline
when i did my waterpump i put it in then put togeather the rest of the car and then just hoped i did everything correctly so i wouldnt have to take it all apart again.
