Old 08-18-2007, 08:29 AM
matt79 matt79 is offline
What is Bank 1?
I scanned the check engine light. I got code PO 420. Which says catalyst efficiency below threshhold (bank one). So where is bank one located? I'm guessing it is the O2 sensor on the rear exaust manifold...
Old 08-18-2007, 10:11 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: What is Bank 1?
Welcome to AF!!
Most of the single exhaust cars only have bank one. Some do have two banks but in your case I suspect you either have a cat issue or the O2 sensor is bad. The sensor is easier to change but if the code does not go away you will need to change the cat.
Old 08-18-2007, 10:49 PM
MasterTech8 MasterTech8 is offline
Re: What is Bank 1?
On a V6 or V8 engine bank one is the side of the engine that cylinder one is on. Then bank two is the side of the engine that cylinder two is on
Old 08-19-2007, 10:49 AM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: What is Bank 1?
Actually if it is a V8, bank 2 is on the right (passenger side).
Sensor 1 is always before the catalytic converter (sensor 2 is after)
1999 Grand Am SS 3.4 OHV
Old 08-19-2007, 01:14 PM
Ron G. Ron G. is offline
Re: What is Bank 1?
In the 3.1 engine (transverse mount) bank one is at the aft (firewall) side.
In the 3.0 & 3.3 engines (transverse mount) bank one is at the fwd (radiator) side.
