what's wronge with my car?
???? WTF??
Re: what's wronge with my car?
I wan't very clear but I was talking about the knock.. even at idle.. but I figured it out.. My sensor wire was grounding out! so I will fix it soon and that should fix it..
Jason |
was this log upon startup? if so, your O2s seem to be cycling properly after 39 secs, once you let it idle. but since your knock cycles below 10 counts, its probably a wiring problem or a faulty sensor. check the wiring (and i mean ALL of it from the sensor to the ECU) before replacing the sensor.
http://www.3si.org/forum/showthread....ighlight=knock
93 3000GT base K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2 coming soon: adj. cam gears | bi-xenon HID retrofit |
Jason
