Go Back   Automotive Forums Car Chat > Toyota > Avalon/Pronard
Old 08-17-2007, 05:16 PM
wavetrapper wavetrapper is offline
1998 Avalon Intermittent Starting Problems
We have a 1998 Avalon which we love, about 125,000 miles. It has pretty much been flawless until the past 2-3 months. It has developed an intermittent starting problem....usually on the first start of the day or after it has been sitting for several hours.
90% of the time, the car starts right off. Sometimes it tries to start (in fact I think it has started) but when I release the key, it has not started. It will usually start on the next try. More worrisome, sometimes I turn the key and NOTHING happens, I don't even think there is a click. However, if I just keep turning the key from off to on then the car will eventually start like nothing was wrong...usually on the 2nd, 3rd, or 4th try.
I have taken it to 2 Toyota dealers who basically tell me that until the car is dead-on-arrival, they can't / won't diagnose it. The battery was replaced as part of the "fix" (didn't help). The spark plugs have recently been replaced also.
Is there some logical sequence of things to check / replace. I guess this is going to come down to part-changing. I was wondering what you would replace and in what sequence. Any help you could provide would be very much appreciated. I have pretty much given up on our Toyota dealers and will try someone independent if I came "armed" with some information.
Thank you very much.
Old 09-27-2007, 02:44 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: 1998 Avalon Intermittent Starting Problems
Do you still need help?
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 10-29-2007, 09:25 PM
Joe W Joe W is offline
Seems like it would be the ignition switch...?
Old 01-31-2009, 10:14 AM
RudeDog6999 RudeDog6999 is offline
Having the same problem with a 98 XLS, car always cranks, but starts only 95% of the time. problem never lasts long enough for normal fuel delivery or spark tests. No CEL activity, or stored codes. Any suggestions?
Old 02-02-2009, 09:19 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
In the future, please do not resurrect old threads, but since this one was not resolved, I'll let it slide for a bit longer to get an answer.
Sounds like the starter brush contacts have worn out. If you can tap on the starter housing with a hammer, this might jog the starter just enough to make electrical contact and start up. There is a starter repair kit you can buy to replace the brushes. Cheaper than a new one with more work involved, but the procedure is not difficult. Let us know the outcome so we can close this thread. Good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
