Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 08-17-2007, 04:14 PM
Mitsu970 Mitsu970 is offline
wiring issue
ok, so, I did all the searching and didn't find out anything about how to fix this little problem I have. So the deal is that I just installed some new gauges overlays on top of my factory gauges, but they need a power source. In the installation directions (which really didn't help all that much anyways), it says that I should connect the power wire to the parking light. I cannot find where this is. The only wires I can even see right now are the ones that go to the dimmer switch, and those are covered by some squishy cloth thing. So, if anyone can help to steer me in the right direction for where to hook the power source up to that would be great. Thanks.
Old 08-18-2007, 12:15 AM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
Re: wiring issue
I hooked mine up using a toggle switch spliced into my cig lighter. I used a 2 pole toggle that had the gauges hooked to one end, the power hooked to the other, and the ground from the gauges hooked to one of the bolts for my parking brake. Granted you need to hit a switch to turn on the gauges, but I think it is easier than trying to figure out what wires belong to the parking lights.
2000 Fed. Spec GT-"Lafawnduh"
Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp
Old 08-18-2007, 03:11 AM
Re: wiring issue
thanks for the idea. It sounds pretty solid. I'll let you know how it goes
Old 08-20-2007, 03:14 PM
808drifter 808drifter is offline
Re: wiring issue
If you dont mind running a longer wire, Just wire it up to yuo blinker.
you just need to test witch one of the plugs on the conector powers the light when you turn on the headlights and witch one makes it blink. thats how I hooked up my Halos.
Old 08-20-2007, 11:46 PM
rodbls's Avatar
Re: wiring issue
I hooked up my halos the same way, but that was really the only solution for up there other than to wire them through the headlight itself, but going through the parking lights will allow you to run your halos when you only have your parking lights on (which I never do)
Old 08-22-2007, 08:12 AM
urbanagolfer urbanagolfer is offline
Re: wiring issue
The best way to hook up an acc like that is via an existing wire. If you have a test light use it to find a wire that has power when the lights are on and none when the lights are off it takes 15 minutes more but you don't have that extra wire hanging around waiting to short out. You can also look at your fuse box and find the location of the fuse for your running lights then pull the bottom of the box off (takes a whole 3 minutes) and find what color the wire is. Then go under the dash and find that wire test it to make sure and splice your acc wire in.... I encourage a quick solder will do the trick...
