Old 08-17-2007, 10:59 AM
JohnErtle JohnErtle is offline
Left Turn Signal
I have replaced both bulbs but the left turn signal does not blink. It stays on and is steady. Same thing happens when the hazards are turned on. Any one have any ideas on how to fix?
Old 08-17-2007, 11:18 AM
lecky4 lecky4 is offline
Re: Left Turn Signal
Two possible things, 1; weak battery charge, it's not probably this as you would have other problems like starting or, 2; the relay for the left hand side is stuck.
Old 08-17-2007, 11:30 AM
Any idea on how to unstick the relay? Or is it easier to replace it? I'm not certain where it is in the car, although I assume it is near the fuse box under the dash?
Old 08-17-2007, 12:20 PM
Replace it, the're just a push fit so it's easy and also a sealed unit so you can't work on them.
Old 08-18-2007, 08:58 AM
Loekee75's Avatar
Loekee75 Loekee75 is offline
Send a message via Yahoo to Loekee75
Are you absolutely sure that every bulb, including the tail light bulbs, on the left side is in working order? Which bulbs did you replace, front or back?
http://www.cardomain.com/ride/2653398
1992 Buick Park Avenue (Daily driver)
2001 Saturn SL1 (gas saver)
Old 08-18-2007, 06:31 PM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
I'm suspicious of the flasher (relay), but since BOTH hazards and blinkers are malfunctioning, then I'm also suspicious that a bulb may have a short. The hazards and blinkers operate off separate flashers and the odds of both of them simultaneously going bad is minimal.
If all the bulbs are found to work, then replace the flashers (~$3 each) and troubleshoot from there. To replace: remove hush panel under column, look up under column and to each side. Each side there should be a small aluminum or plastic cylinder about the diameter of a quarter. Remove both, they should have two electrical prongs in a V shape. Reverse procedure to replace.
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Old 08-19-2007, 05:13 AM
A short across a bulb would blow the the fuse, and a short from another system would mean the fault would only occur when that other system is on. If your like most and leave your heater and radio on it may be worth switching them off.
Old 12-18-2007, 06:15 PM
PatrickWK PatrickWK is offline
I have a similar problem with a 97. I thought I had it all corrected since I replaced the turn signal relay. All bulbs light up fine. Took it in for inspection all passed. Two days later the left turn bulbs on the front won't flash. They all come on fine and the left rear flasher works brakes work but the front left just won' t flash. Emergency flasher works all bulbs flash except front left.
Can't see how it is a bad ground or even a short since the bulbs light up proberly. Like I said I replaced the relay worked for awhile and now it don't!?
Old 12-19-2007, 08:46 PM
Well we took the cover off under the steering column and droped the wires. Checked the flasher relays and wiring for damage/corrosion. Then tried it again and it all worked. Put it back together and it still works. Kind of strange. There must be a pinched wire under there that somehow loses contact causing the signal from delay to be cut off.
