Old 08-17-2007, 10:34 AM
Bob Kuhlman Bob Kuhlman is offline
Transmission will not engage in any gear
Recently overhauled transmission with new torque converter. Fluid level ok. When shifting through all gears, transmission does nothing. Could this be an electrical problem?
Bob Kuhlman
Old 08-17-2007, 10:08 PM
Blue Bowtie's Avatar
Registered Offender
Re: Transmission will not engage in any gear
What year/engine?
Old 08-18-2007, 04:00 PM
Engine - 3800 V6 series II, Transmission 4T65E
1998 Park Ave
Bob Kuhlman
Old 08-18-2007, 06:45 PM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
Overhauled as in rebuilt? The first thing that I thought of was insufficient fluid, but you say the level is "OK". Have you checked the shift linkage from the cable to the linkage (located at the park/nuetral switch)? There's not a whole lot holding 'em on and it could have popped off from previously not being attached fully.
If it was recently completely rebuilt, then I'd say someone didn't put it back together right. 4t65's are pretty complicated to rebuild. Have any kind of warranty from the rebuilder?
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Old 08-18-2007, 08:31 PM
New neutral safety switch installed and linkage is connected. I can shift through all gears but the transmission does nothing.
Bob Kuhlman
Old 08-18-2007, 09:55 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Does the pump build pressure? You can at least take one of the cooler lines loose and see if fluid is circulating.
