Old 08-16-2007, 09:24 PM
patrick-bowtie patrick-bowtie is offline
2000 Silv erado - Fuel Pump/Electrical Problems?
I have a 2000 Silverado 1500SL 5.3L Extended Cab. Mileage is at 180k. I bought the truck used in 2001. The fuel gauge has always been sporadic. There has been slight hesitation over the past 2 years when the truck is at speed. This happens very seldom. Last week while driving the truck hesitated a few times and all 6 gauges jumped - moving at the same time. The warning lights also lit up at the same time. This lasted only a few seconds. About 5 miles down the road it happened again. Approximately 4 days later the same thing happened, but hasn’t happened since then. Please help.
Old 08-16-2007, 09:28 PM
knogoodidleft knogoodidleft is offline
Re: 2000 Silv erado - Fuel Pump/Electrical Problems?
when you say hesitate you mean like the fuel pump dosent pump enough gas and it sputters? to me it seems like it could be an electrical problem, maybe a loose ground/connection.
Old 08-16-2007, 09:33 PM
Yes, it seems like it's not getting gas for just a split second. The fuel pump has also been whining for the past couple of years. Forgot to mention that. How would I check for a loose connection?
Old 08-16-2007, 09:51 PM
well seeing that recently it made the dash spaz out I would check the battery terminals, as for a bad ground I think it requires some troubleshooting, I never had to mess with it
Old 08-17-2007, 12:53 AM
fillupread fillupread is offline
How exactly did the cluster gauges jump? Did the peg high, drop to nothing? Did they come back? Are they correct when working? Are you loosing radio presets?
Old 08-17-2007, 09:02 AM
silverado122775's Avatar
silverado122775 silverado122775 is offline
Do you have a GMC or a Chevy? SL is the GMC version of the Silverado. not that it matters.
Your fuel gauge being sporadic is the caused by the sending unit or the instrument cluster. NOw you have introduced a new problem which could be the fuel pump/sending unit going out completely and/or your instrument cluster going out. You have 180K miles on the truck. I would replace the fuel pump/sending unit. chances are you will need to replace it anyways.
If you gauges are still acting up, then replace the cluster.
2000 Silverado Z71, 5.3L, K&N GenII Air Intake, Y-pipe Exhaust (no muffler), Bosch Platnium +4 plugs, 242k miles and still running.
Old 08-17-2007, 10:31 AM
Before I would replace a $400.00 part I would test it first. The sending unit works on resistance. Use an Ohm meter set to measure Ohm's. Take the sending unit out, connect the leads from the Ohm meter to the sending unit and work the float arm slowly by hand. The resistance will increase gradually as you move the level arm. If the meter moves as smoothly as you move the level arm then the sending unit is fine. If it all of a sudden hits a spot and goes nuts, you need a sending unit.
Old 08-17-2007, 06:24 PM
Sorry for the confusion, it is a Chevrolet. That was a typo. As far as the gauges - they went back and forth pegging out both ways - and it only lasted a few seconds. I'm sure it probably does need a fuel pump and I'll end up replacing that. I'm wondering if that will solve all of the problems once that is replaced.
Old 08-17-2007, 09:41 PM
You can replace your fuel gauge or sending unit all day long. That isnt going to fix all your gauges jumping around.
Old 08-23-2007, 11:10 PM
Bailcolo Bailcolo is offline
1999 Silverado
I changed the fuel pump and still no fuel how doi I prime ejectors
Old 08-26-2007, 03:48 PM
rhandwor rhandwor is offline
Have you checked the relay for the fuel pump. On my 2000 you could pull another relay to check. If bad replace with a new unit. A plugged fuel filter will cause a no start. Check the fuel pressure regulator. Use a ohm meter and check that you have power to the pump. You should be able to hear the pump.
Old 08-26-2007, 05:35 PM
Sonny01's Avatar
Sonny01 Sonny01 is offline
You can get a new fuel sender on eBay for under $150...if he goes to all the trouble to pull the bed/drop the tank then at 180K I think he should just replace it...don't you?
Old 08-26-2007, 05:51 PM
I was answering the no fuel question as he replaced the pump with no fuel. The other post you are answering I would follow your suggestion. Also the theft system will shut off power to the injectors if it goes bad.
Old 08-26-2007, 07:21 PM
Sonny01's Avatar
maybe "don't you" sounds a little strong....maybe I should have put "don't you think that's a good idea" instead.
Old 08-27-2007, 03:00 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
I would check to see if you have power to the fuel pump relay.
One thing to check is the ignition switch on those vehicles. If the switch has bad contacts, this can cause the conditions you are describing.
A quick check would be to turn the switch to the ON position and look at the SES light..if the SES light is not on, then most likely you have a bad switch
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
