4WD Light
On my way home today my "service 4wd" message came on. Don't know what the problem would be. Please help!
Re: 4WD Light
take it by autozone they will run/clear the code
Re: 4WD Light
i was doing some reading in a book and it said to shut off the engine and then start it back up and see if the message comes back on. i did so and it stayed off. but does that mean that there is something wrong???
Re: 4WD Light
It could be the 4wd switch on your dash. check google
Re: 4WD Light
Ok if that is the case then wouldn't the light be flashing??
Re: 4WD Light
If the "service 4wd" light came on there should be a code stored in the 4wd component memory. It's really the only way to tell what happened.
By the way, what year, model & engine?
57 Chevy 210 65 Olds 442 Convertible (Another one sold) 75 GMC Vandura 3/4 Ton 1999 K2500 Old Body Style Suburban (Gone but not forgotten) 05 Dodge Ram 3500/5.9 Cummins 2012 Toyota FJ Cruiser |
Re: 4WD Light
Today at work i pulled the codes that should be in the system and there was none. So i am guessing that is not a problem or if there was then it was a false problem. The Truck is a 2004 Chevy Silverado Z71 with the 5300 vortec engine.
Re: 4WD Light
OK that's a good thing. However, if the light comes back on again check it for codes while it's on and active. Hope you're using a scanner that's capable of accessing the 4WD system.
