Old 08-16-2007, 06:19 PM
jaxXxn jaxXxn is offline
Help!!! Ecm/fuel Fuse Keeps Blowing!
1992 Pontiac Grand Prix 3.1, 3spd...umm...i dont really know what is causing this error...it just started happening...it stopped for a while after i replaced it...but now it happens EVERY TIME I TURN OFF THE KEY!...only then does it blow...im stumped guys...it only happens when you turn off the ignition...ive checked the grounds to the tranny since i had it replaced...i really dont know...any help would be appreciated!
Old 08-17-2007, 05:45 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Help!!! Ecm/fuel Fuse Keeps Blowing!
Try running a separate ground from the ECM to the Subframe. If that doesn't help, you may have water intrusion in the ECM and it will need to be replaced.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 08-17-2007, 10:32 AM
k i will try that out...i replaced the fuel pump last year....im gonna trace those wires out n make sure nothing is touching...but i dont know if thats why it does it when u turn off the ignition...keep comin with idea's guys...i need to get this resolved...
Old 08-17-2007, 03:20 PM
richtazz's Avatar
The only thing I can think of is that it's backfeeding ground through some ignition controlled circuit's positive side, and when you cut the switch it loses ground, arcs and pops the fuse.
