Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 08-16-2007, 05:15 PM
evildragon evildragon is offline
engine cleaning
This is sorta a three part thread...
1. I just got done cleaning my engine quite a bit today. How does the improvement look?
Before:
http://blackevilweredragon.spymac.com/mycar/7.jpg
After:
http://blackevilweredragon.spymac.com/mycar/8.jpg
2. Is it me, or does it look like the water pump looks worse? The "Before" picture was taken a year ago, before I started even driving this car, or got it started.
3. How do you suggest to clean an engine, better than what I've done so far? It's SO hard and back breaking, constantly leaning over the engine, and sweat dripping from your forehead.. There's GOT to be an easier way.
My one and only car!
1994 Chevy Caprice Classic LS
L99 Engine
Old 08-16-2007, 05:29 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: engine cleaning
Before:
After:
I don't know how you cleaned your engine, but I always use a high pressure hose, being mindful of the ignition system, carb and anywhere that water can find its way into the engine. You've seen the pictures on my website (in my sig) of how the engine comes out. I clean it once every 3 months or so - never giving any deposits the opportunity of hardening or baking on. I do it at night time, so I never really break a sweat (unless it's humid outside). Pretty easy to do. You can use the high pressure hose at a carwash, being mindful of the things (except the carb) that I added above. Pay particular attention to the water pump area (OptiSpark distributor doesn't like moisture).
If you use anything corrosive to clean the engine (Greased Lightning, Simple Green, Orange Power etc), that will cause the water pump to look like that. If you do use that stuff (I do), just keep it away from aluminum and you should be fine.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 08-16-2007, 05:36 PM
Re: engine cleaning
The scary part, is that this was my first time cleaning my engine, and the water pump looked this way since I got the car. So I feel the water pump is actually leaking somewhere.. But the coolant levels are always fine.
I used a wet rag to clean my engine, I literally scrubbed the damned thing for hours, before using a high powered air hose to get the leaves and hair (yes, long womans hair.. i wont even begin to figure that out). I didn't want to use a water hose to clean it, because I didn't want anything wet (especially with the already existing on-going problem of hesitation)...
L99 Engine
Old 08-17-2007, 01:33 AM
kahjdh's Avatar
kahjdh kahjdh is offline
Re: engine cleaning
What about steam cleaning? Detail shops do that and they turn out pretty good but I dunno where you can do it.
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 08-17-2007, 10:41 PM
Blue Bowtie's Avatar
Registered Offender
Re: engine cleaning
I use a garden hose (hot water), detergent, and wipe things dry.
In about 20 minutes, I go from this:
To this:
From this:
To this:
From this:
To this:
From this:
To this:
Old 08-25-2007, 06:44 PM
Blazin_Jason Blazin_Jason is offline
Re: engine cleaning
Just did the engine on a 4runner for a guy at work. Used our new 2000psi max, 250 Degree $5000 steam cleaner. This thing gets HOT! Completely effortless and works good. Sorry no pics. BB's work looks really good, btw.
