Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 08-16-2007, 05:05 PM
scottyec76 scottyec76 is offline
Electrical Problems
I have a 97 that won't hold a charge on the battery. Replaced the elternator still won't hold a charge. Took the new alternator back to advance, they put it on the machine,tested it and it held a good charge. Ruled out a bad alternator. Checked all fusible links and fuses, they're fine...ANY IDEAS??? Anyone else ever have this problem? Is there any alternative to tracing the wires? Know of any hidden problems I should look for with this thing? Any suggestions other than wire tracing is good. runaround
Old 08-16-2007, 05:45 PM
FL 3.2L FL 3.2L is offline
Re: Electrical Problems
I'd suspect this alt IF the battery is good. Use a good rebuilt or new. Search for recommendations. I've had perfect performance from a NAPA alt for over a year.
'97 Rodeo LS 4X2 Dueler Alenzas 4L-30E 200K
'96 Jetta 249K
'97 TJ 156K
'02 VW Cabrio 70K
'03 E46 107K
Old 08-16-2007, 06:34 PM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
Have the battery tested under load. And check all the cable connections to make sure they are tight and clean.
Isuzus are very picky about alternators. They will eat up house brand box store ones if they work at all. Recommended are rebuilt by bosch, OEM, or napa.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Old 08-16-2007, 09:29 PM
Here's what it's doing...I charge the battery, start the rodeo, within 10 minutes it's down to 9.5-10 volts wont drop below that according to the gauge on the dash, runs fine, lights work and everything. As soon as I shut it off that's it, the battery needs charged again. It won't shut off on it's own, but won't start if I shut off the key.
Old 08-16-2007, 10:08 PM
pharm_rodeo's Avatar
pharm_rodeo pharm_rodeo is offline
If your battery is brand new then I would suspect the alternator. Heed the advice about using a Bosch or OEM alt. IF you run a search you'll find plenty of posts related to this topic. I find that Rodeos are prone to a lot of electrical problems, so I keep a $20 multimeter handy. You can run your own simple tests so it's worth the investment.
1994 Acura Integra LS---212K+
1998 Isuzu Rodeo S 3.2L 2WD---176K+
Old 08-16-2007, 10:09 PM
trooperbc's Avatar
trooperbc trooperbc is offline
well you got all the info you can possibly get above. from your last post sounds like a cell in the battery is shorted, but you need to test it or get it tested, then move onto to the rest of the charging circuit including the wiring and connectors and grounds and then the alternator.
//bc
1992 trooper 3.2L v6 sohc automatic...as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
