Go Back   Automotive Forums Car Chat > Ford > Contour
Old 08-16-2007, 04:57 PM
michaeleast1 michaeleast1 is offline
Overheating
I have a 95 contour which I've changed the thermostat twice and still overheats, or the needle rides on the red. When I turn the ignition key on in the morning, te needle immedietly goes to the M in normal. Within 5-6 miles its riding the edge of normal and red. If I remember right, it used to begin in the white at the far left when starting the first time of the day. The engine light comes on frequently for a few seconds, then goes off. I've tried t have that diagnosed but nobody could ever duplicate why the light came on, and the computer did not store the info. However, I didn't have cooling problems when this was going on in the past, and thought I would throw that in there just incase.
My water and coolant is full. This car has 175K miles on it and has been a great car. I don't want to crack a head or gasket or harm it in any way. I think its probably got another 50-75k miles to go.
Old 08-16-2007, 06:56 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Re: Overheating
Give me the engine type and I'll give you a link to contour.org with the answer.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 08-21-2007, 11:44 AM
Re: Overheating
Its a 4cyl DOHC 16V
Old 08-21-2007, 04:07 PM
Re: Overheating
Originally Posted by michaeleast1
Its a 4cyl DOHC 16V
Okay. Second question. Are you for sure the car is overheating? I know the gauge indicates its hot, but is the coolant actually boiling? Zetecs are notorious for having bad temperature sensors and reading incorrectly.
"The CEG Nazi"
www.contour.org
Old 08-22-2007, 12:53 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: Overheating
if the gauge immediately rises to M on a cold engine then the temp sender or gauge is bad. I doubt its actually overheating
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 08-24-2007, 02:13 PM
Re: Overheating
Well, here's the problem now. The guage (after sitting for 14hrs) will go from cold to hot with 1/4 mile. And when I say Hot, I mean buried in or past the red on the temperature guage. If this is a sensor or smething, what do I do to change it myself? And for what part am I asking for?
Old 08-24-2007, 05:18 PM
Re: Overheating
Obviously, its impossible for a car to overheat that fast. You could probably run zero coolant and it wouldnt even overheat that fast. Im sure if you popped the hood like I suggest earlier, you would see that the coolant is perfectly fine and not bubbling. Its the sensor. Ask the dealership for a coolant temperature sensor.
"The CEG Nazi"
www.contour.org
