Go Back   Automotive Forums Car Chat > Honda > Integra
Old 11-15-2002, 12:33 PM
jedi jedi is offline
should i swap..help!!!!!
Okay i recently found out i can get honda/acura engines for about $1500.00...with tranny..and other needed parts..just no ECU OR MOTOR MOUNTS....im not talkin little d16's either im talking about b18b and b18c's ....now my car has the b18a engine with auto tranny and ABS brakes...would it be worth doin a swap and makin my car a standard etc...or not?...also what could i do about the missing ecu issue ?
oh and the engines are low milage usually.
Old 11-15-2002, 02:10 PM
redmanjd redmanjd is offline
you can run a b18b off of your b18a ecu without any wiring changes.
i have it done on my b18b powered 90 civic. all you do is use your b18a ecu,alternator,started,injectors,distributor and mounts. and the trans bolts right up
1995 mustang gt gt40 crate swap on going idle issues dcevil79 Mustang Problem Diagnosis 1 09-16-2010 05:35 PM
1995 olds achieva engine swap help. handymann3 Achieva 2 01-21-2010 09:26 PM
93 D16Z6 swap into 91 CRX SI, Need help riptech7 How-To's and Walk-Through's 2 01-08-2010 07:48 PM
94 Psprt 3.2L4x4 diesel swap, wasting my time? bagelpsychic Rodeo | Passport | MU 2 05-04-2009 07:47 PM
what colour should i.....? help! .porkchop. Car Modeling 11 01-20-2003 04:09 PM
