Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 08-16-2007, 04:06 PM
cbmcleaning cbmcleaning is offline
A/C Vents Not working properly..?
My 2003 Impala A/C - Heater - Defrost vents always seem to remain OPEN at the same time. Moving the dial that is supposed to change them does not good.
IT is summertime here and over 100 degrees each day...my A/C system works, but the air is blowing from ALL vents and so the car is not cooling down properly....
Has anyone had this issue...and if so....how can it be fixed....?
Thanks
MV
Old 08-17-2007, 06:02 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: A/C Vents Not working properly..?
If you've recently worked on or near the battery, check the vacuum supply line that runs from the intake to the firewall. It is common for this vacuum line to be accidentally damaged when working on the battery. There is a rubber junction near/behind the washer fluid jug that may have become disconnected also.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
