Old 08-16-2007, 02:59 PM
cmjrbking123 cmjrbking123 is offline
tranny refill help.
i heard you can refill the tranny through the vss???? hole where is it? on my 89 crx i cant find the dam thing, does it have a small hole on top of the tranny? thanks.
Old 08-16-2007, 04:00 PM
viper-blue's Avatar
viper-blue viper-blue is offline
Re: tranny refill help.
the vss is on the firewall side of the tranny. You will see a cable running into it that comes through the drivers side firewall and runs to the vss...personally I don't know why anyone goes through that trouble. The backup switch is on the front of the tranny and is easier to get at. It has two wires running to it and its real easy to see..just make sure you disconnect the wires from it before you wrench it off. Its pretty much directly under the dizzy. 2 liters will fill er for you
89 crx SI - spoiler, custom viper blue paint job, Z6 just completed, stock 14's with a 3 inch drop, sidemarkers, and the stereo
"my crx is like my woman: don't like anyone touching her, or driving her but me!"
Old 08-16-2007, 04:32 PM
Thanks viper. after reading your responce it's the little plug right under the dizzy with a small bolt?. just pour 2 quarts in there?. it's on the side of the tranny right.
Old 08-16-2007, 04:53 PM
viper-blue's Avatar
no its not on the side. Its right on the top of the tranny and there are two wires connected to it. It doesn't have a bolt attaching it. Its a threaded sending unit that screws into the trans..its basically the only thing screwed into the top of the tranny with wires connected to it...other than the vss you were talking about earlier which is harder to see and on the backside of the tranny
Old 08-16-2007, 07:06 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Its actually on the bottom of the tranny, front side. Under the shift lever.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 08-16-2007, 11:51 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Ive never had a problem with filling it up where your supposed to. Just get a funnel with a flexible tube on it. But even the VSS is easy to do too, its not something thats hard to reach.
but I guess thats just me.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 08-17-2007, 04:36 AM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
I use either an electric pump that will handle heavy weight oils, or use a hand pump, or one of those nice oil bottle caps that has a valve on it, and hook a hose to it.. put the hose in the factory fill location, and open the valve...
Old 08-17-2007, 05:12 PM
viper-blue's Avatar
I'm jealous guys. i would love to fill through the actual fill hole. I will honestly say I have not ever came across a bolt, or nut I can't crack with a little elbow grease, and patience. That F'in fill bolt on my SI tranny just won't come off. I even had the tranny out of the car while I slapped it on my Z6 and I swear I just got sick of messing with it. Not even a pipe wrench will move that sucker. Lol! maybe if I could find a bench vice that will hold a tranny I could crack it. Me working the pipe wrench with a leverage bar, two buddies holding the tranny...lol, they were flip flopping all over the place trying to hold the tranny still. Never came across such a stubborn fastener/plug
Old 08-17-2007, 10:16 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
sounds like popeye got a hold of your tranny )
Old 08-17-2007, 10:27 PM
viper-blue's Avatar
Its unbelievable, lol. Your right popeye, or its somehow welded itself. 315,000kms on her and no grinds...synchromesh for life
Old 08-18-2007, 01:30 AM
Tony's Avatar
TLD Member #1
Big impact gun
Tony
Old 08-18-2007, 03:57 AM
FrodoGT's Avatar
Synchromesh 4 life.
Current project:
Rio Red 91 hatch.
Old 08-18-2007, 03:54 PM
try a lil heat... get a braising torch and heat it up a lil bit while hitting it with PB blaster or something similar the next time you have it out of the car... then get a socket that will fit it, and somewhat aggressively tap the socket into the plug, toward the tranny.. not so hard you damage it tho... then put a breaker bar into the socket, and make sure it's not going to flop sideways on you (also works with a ratchet you don't care about... or a craftsman/snap-on) and get a 2-3 lb mallet, give it a good smack about halfway down the shaft of the wrench... sometimes constant pressure isn't enough... the force of sudden impact might just jar it enough to loosen the aluminum corrosion from the steel bolt. Do this 4-5 times, and you should be able to turn it with some stress.. just make sure before you put it back in that you clean it and put some anti seize on it...
Old 08-19-2007, 12:19 AM
Tony's Avatar
TLD Member #1
A sudden impact always works better than constant pressure. Its why impacts work so well. Its also how I can remove most brake lines without a line wrench that everyone has to use in order not to round it off.
Plus with a sudden impact, its not as big of a deal to hold the transmission still...helps, but its a little easier to do.
Tony
