Old 08-16-2007, 02:57 PM
rmanick1 rmanick1 is offline
Smile P1450 Error Code
Please Help.
The “Service Engine Soon” light recently came on in my 2001 Ford Taurus SES with a 24 valve DOHC engine. I read the trouble codes which indicated a "P1450 malfunction" which I was able to identify as the “Inability of Evaporative Emission Control System to Bleed Fuel Tank”. I proceeded to replace the fuel filler cap, since it was the easiest thing to do, but that did not fix the problem.
I also checked for kinks in all the hoses and fuel lines in and around the EVAP canister which I believe is located in the rear underneath of the vehicle. However, I did not come across any indication of any problems.
I would really appreciate some help figuring out what the actual problem is along with advice as to how to proceed and troubleshoot the problem and a suggested potential fix. Any help would be greatly appreciated.
Thanks in advance.
Old 08-16-2007, 10:57 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: P1450 Error Code
Doesn't seem to be a common issue with an easy typical fix.
It sounds like you may already have this information, but typical causes for this code would be:
  • Blockages or kinks in EVAP canister tube or EVAP canister purge outlet tube (between fuel tank, EVAP canister purge valve and EVAP canister)
  • Fuel filler cap stuck closed (no vacuum relief)
  • Contaminated fuel vapor elbow on EVAP canister
  • Restricted EVAP canister
  • CV solenoid stuck open (partially or fully)
  • Plugged CV solenoid filter
  • EVAP canister purge valve stuck open
  • VREF circuit open (harness near FTP sensor, FTP sensor or PCM)
  • Damaged FTP sensor
-Rod
