Old 08-16-2007, 03:12 PM
travis2822 travis2822 is offline
Send a message via Yahoo to travis2822
Fuel Gauge not reading correctly
99 2dr 4x4 Blazer
Just this past week my fuel gauge started showing as full then the next day it would show as empty (with the light on) then it would go back to full.
I've researched a couple of posts and they seem to be contradicting.
One would say replace the whole pump and another would say that there is a ground wire that isn't grounding properly.
Could someone clarify if there is a ground wire that my be faulty on the body and its location or do I have to deal with it until I either want to change the pump or the pump goes bad?
Thanks for all of the assistance.
Old 08-16-2007, 03:27 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Fuel Gauge not reading correctly
Originally Posted by travis2822
99 2dr 4x4 Blazer
Fuel sending units the 99 grounds at the ground splice pack on left side of dash.
You can check for good ground at the wiring plug in going to fuel pump module in tank.
If two black ground wires there check both for a good ground.
MT
Old 08-17-2007, 11:17 AM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
MT-2500 is mot likely right but overall how is your truck running?
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 08-17-2007, 12:55 PM
Truck is running pretty good. I have a couple vacuum issues. The AC hisses a little and sometimes when I stop the I can hear the 4x4 egaging a little bit but other than that nothing is wrong.
