Old 08-16-2007, 07:50 AM
Hellbilly Hellbilly is offline
Striped Distributor shaft???
NOt sure if i got the correct name of the part or not but, I hear a major ratting comming from around the distributor cap...the motor will run fine then idol will change and it will rattle and cause the motor to miss..while driving the motor will take spells and miss and backfire threw the carb....any ideas?? and how to fix it???
Old 08-16-2007, 08:15 AM
taillight taillight is offline
Re: Striped Distributor shaft???
You did not say what year or engine but there were some distributor gear problems.
Old 08-16-2007, 08:31 AM
Crap..Sorry bout that..
89 s10 blazer 4x4 auto 4.3TBI
Old 08-16-2007, 08:42 AM
inafogg inafogg is offline
you didnt mention miles ill guess its over 100k on the 4.3 distributor is in rear of engine rught?? if your getting back fire back through carb valve timing is off have u checked the timing? check distributor cap/rotor
Old 08-16-2007, 08:45 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Set the engine on TDC compression no 1 cylinder.
Remove dist cap and check for up and down play and sideways play.
Then remove dist and check the dist gear and the pickup coil for being centered or lose.
If it is worn out a rebuilt dist is a good way to fix it.
MT
MT
