Go Back   Automotive Forums Car Chat > Honda > JDM Motor & Parts info/chat
JDM Motor & Parts info/chat Discussions on Mugen, Spoon etc. Plus, info on motor swaps (b18 's, b16's h22's etc) and other JDM info!
Old 08-16-2007, 05:24 AM
ByonSho ByonSho is offline
obd0 b16 w/ obd1 ecu and d16 wiring harness question.
So my 94 sol S has a OBD0 B16a swap with a P30 OBD1 ECU, and the stock OBD1 D16 wiring harness. My question is, is there a wiring diagram I can look at so I can hook up my VTEC and O2 sensors, amongst other things?
Thank Chad
Old 08-18-2007, 02:51 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Re: obd0 b16 w/ obd1 ecu and d16 wiring harness question.
http://honda-tech.com/zerothread?id=724252
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 08-20-2007, 12:08 AM
Thanks that worked perfect, but I still need a few other things, my o2 was already hooked up, but I have wires from my stock harness that aren't plugged in .
Old 08-25-2007, 05:58 AM
nevermind, found them all. Saved $80 doing the wiring myself.
Old 09-29-2007, 12:15 AM
boy704 boy704 is offline
the stock harness fit the b16a engine? Umm I try it but does not fit. what kind of mod did you do to make it fit? I have a 93 del sol S and putting the same motor in.
Old 09-29-2007, 01:52 AM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
3rd post down http://www.honda-tech.com/zerothread?id=1691791
Old 11-18-2007, 06:58 PM
freshane freshane is offline
Hi I have a wiring question but its for a B16A Sir II engine being installed in a 1994 Honda Civic Si Coupe with Auto tranny. I originally had a D16Z engine in my car. Is there a plug n play harness I can purchase to make the wiring easier?? Thanks for any help.
