Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 08-16-2007, 01:17 AM
204beast's Avatar
204beast 204beast is offline
winter/power button
on my 99 3.2l v6 on the gauge cluter when start up it shows all the types of warning lights and and other indicators
there is a winter and power indicator on the top right hand of the gauge cluster, i have both types of button winter/power
is it suppose to light up and indicate if its engaged on the dash??
my 99 3.2l v6 dosent have power anything(windows,locks)but it came with A/C i noticed that i have loose harnesses behaind the under dash cover that should be plugged in to controls but im geussing that its for the other models that are fully loaded, what are they for ?
and is the winter/power button for the fully loaded models??
thanks for reading
99 RODEO -R.I.P
01 rodeo -5" independent 4x lift
9000 rancho shocks
manual locking hubs
18x9.5 BBS rims
285/60/18 toyo open country A/T
02 honda passport leather int
15x10old school rims on 33x12 roughrider A/T
Old 08-16-2007, 02:17 AM
trooperbc's Avatar
trooperbc trooperbc is offline
Re: winter/power button
the winter mode and power mode are two different shifting modes for the automatic transmission.
the winter mode: when you start off from a stop in D Drive, it puts the trans in third gear so that you are less likely to go skidding around when you start off in snowy or icy conditions. otherwise the shifting is normal once you get up to speed.
the power mode: all it essentially does is change the shift points for the automatic transmission so you stay in the lower gears longer before upshifting. this has the affect of giving you more power and can be used around town or in the hills if your trans is hunting up and down gears and putting it into 3 third would be overkill.
for either, it is easy enough to see if they are working. it will be obvious. try them out. if they work, then you know it's probably just the bulb or bulb circuit. if they don't work, then you can check the switch and then go from there.
as for the harnesses and unused connectors. isuzu generally built each model with all the wiring, and used what it needed. so the particular ones you are seeing could be anything, from the power stuff, to cruise control, to .....
good luck
//bc
1992 trooper 3.2L v6 sohc automatic...as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
Old 08-16-2007, 11:23 AM
204beast's Avatar
thanks for the input
99 RODEO -R.I.P
9000 rancho shocks
manual locking hubs
18x9.5 BBS rims
Old 08-16-2007, 10:43 PM
204beast's Avatar
is the winter button suppose to click in like the power button?if so mine dosent,u press it and it springs back up
i still cant tell if the power button is doing what its suppose to be doing,button clicks in but,no indication light or difference
i still got to take it apart to see whats under neith if there is a harness or not
99 RODEO -R.I.P
9000 rancho shocks
manual locking hubs
18x9.5 BBS rims
Old 08-17-2007, 02:18 AM
trooperbc's Avatar
what have you done to tell whether these modes are operational? have you driven it and tried them yet?
btw, i don't know if i mentioned this to you or not. it seems you could do with getting the owners manual (the one that
usually comes in the glove box). if you can't find one on Ebay for cheap, try the publisher for the isuzu owners manuals and factory service manuals www.helminc.com the owners manual will have all the info you are seeking and more. and the service manuals will have all the info for actually working on them if you are interested.
//bc
