Old 08-15-2007, 11:22 PM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
whistling front end at high speeds
Does anyone else have an issue where sometimes at higher speeds, lets say 80 or better, the front end starts whistling? I cant find anything loose, or out of place, and I was just wondering if anyone else had this problem, and what you did about it.
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
Old 08-16-2007, 12:29 AM
notimprezed notimprezed is offline
Re: whistling front end at high speeds
Well a bearing is usually a humming sound so....Is there any other wierd noises from the car? Does it track straight? Did this start recently or been around awhile? I know you cut under the hood to put in the intake, maybe at high speed enough air is being forced into the fender/under the hood its whistling as it blows over something.
Old 08-16-2007, 06:35 AM
LittleHoov's Avatar
Hmm....I hadnt thought about the intake, that could perhaps be related, because it does sound like its coming from that side. But I almost seem to remember it doing this occasionally before I installed the intake.
I may have to experiment with the intake a little and see if anything makes a difference.
